Thread: Bad horn?
Old 02-19-2015, 03:52 PM   #2
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by jeepdad View Post
Hi all. I've read the threads pertaining to the "too sensitive" horn issue and the recommended fixes. However, my horn does something different. When pressed it gives a barely audible whimper of a honk, then doesn't work at all until the ignition is turned off and back on again. The fuse doesnt seem to be the issue. Just a bad horn?
Likely 2 bad horns. The small horns at Autozone fit right in. the bigger horns are too big for the volume where the horns are mounted.
2003 S manual
