Old 02-18-2015, 11:41 AM   #59
Reebuck1
Reebuck1
Gauges
Ok, here is what I am going to try.
I am going to take the used Mother board I got from the old 996 cluster I bought to make the swap with and re-assemble it with my original 986 analog gauges. Install it in the car and see if the car will run. If it does ( I believe it will) then I will take it to Porsche (to use their PIWIS) to TURN ON my volt and oil pressure gauges even though they will not be in the car. This should allow Porsches PIWIS to sink the 986 DME that thinks it is a 996 ROW DME with the cluster that thinks it is a 996 cluster because it now has the 996 mother board in it. Hopefully I can then bring the car home and put the 986 cluster with the 996 analog gauges in and all should work. I will have to recode the 986 mother board so that the two gauges read OPEN.
If anyone thinks I have lost my mind please let me know. I'll report back once I get it all done.
Keep your feed back coming it has helped a lot !!
Reebuck1 is offline   Reply With Quote
