Mot procedure as follows:
- emissions test with exhaust lambda sensor
- all lights, signals, seatbelts and horn
- brake performance and balance testing
- undercar visual inspection, very comprehensive indeed....20 minutes
- tyre check and wheel movement check
- brake inspection, pads, discs and hoses
- full suspension check, raising axle from the ramp and vibrating 4 ways by remote ctl while under car checking for suspension, trackrods and suspension arm movement.
- general bodywork inspection.
Considering my 2.7 is nearly 12 years old and i was warned that " the running costs would be huge"........ in my 1st year of ownership she's cost me £43 for the mot, a set of new tyres and plenty of super unleaded.
Booked in for an oil change and brake fluid change soon and may change the rear pads and discs over the next few months.
Look after your car and she'll look after you.....
Si.
