Originally Posted by Steve Tinker
I don't think the exact chamfer angle is critical - its usually machines on the shaft to help locate the shaft into the bore.
But if you need to know, just measure the outside shaft diameter & the internal chamfer diameter and work from there.
I assumed that the chamfer was the sealing face, like in the AN fittings. I worked out about 15 degrees using your method. If someone could confirm that the chamfer is just for locating and not sealing that would be great.
