Old 02-17-2015, 01:14 PM   #1
martsink
Originally Posted by Steve Tinker View Post
I don't think the exact chamfer angle is critical - its usually machines on the shaft to help locate the shaft into the bore.
But if you need to know, just measure the outside shaft diameter & the internal chamfer diameter and work from there.
I assumed that the chamfer was the sealing face, like in the AN fittings. I worked out about 15 degrees using your method. If someone could confirm that the chamfer is just for locating and not sealing that would be great.
martsink is offline   Reply With Quote
