I opened my hood after accidentally closing it with the battery removed from the car by hooking up the charged battery to the fuse box terminal and door jamb ground as pictured and then using the switch lever by the seat. BUT, it didn't work at first. Then I messed with both the clamps on my jumper cables at the fuse box connection and door latch, pressing in the teeth to make sure I had a good connection (especially the ground) and it worked.
