Old 02-17-2015, 01:41 AM   #3
Troutman
Originally Posted by rdass623 View Post
to remove the installation tools..... pull the radio from it's mounting position. when it is out, compress the locking tabs on the side of the radio. that should release the forks from the radio. it should slide and lock into position without the release tools
That's right ..I worked it out in the end.
So just to re-cap this adapter works really well , is very easy to install, you can leave your CD changer where it is, the only down side is it doesn't charge!! (an iPhone) i'm going to try an old ipod Classic and see if that charges.
Update..tried that and it still doesn't charge..bummer
Troutman is online now   Reply With Quote
