Old 02-16-2015, 12:20 PM   #1
luci5r
luci5r's Avatar
Dead Battery; Hood won't open.
Back story:
Last week I couldn't start the car due to what appears to be a dead battery issue. After getting it jump started, running it around the block a few times, I discovered it wasn't enough to charge the battery. Car still refused to start. Or it appears something is draining the battery.
I finally decided to get the Schumacher SC1200A/CA Battery Charger, which came highly recommended by my Indy Mechanic. The charger arrived today (5 days since my last jump start), so I went to charge the battery. The car has been sitting untouched for the last 5 days, which seemed to have drained the battery to almost zero. The hood won't open.
Current problem:
After seeing countless youtube videos, and being guided by my Indy mechanic over the phone in real-time, my hood still won't open.
This is what I have been doing, which is what the little booklet that came with the car tells me to do:
1. Pull out the Red jumper/fuse in the Fuse Box using the Yellow pick.
2. Connect the Positive clamp to the Red Jumper
3. Connect the Negative clamp to the Door Latch (For grounding)
4. Let it charge (I tried from 10 minutes to 25 minutes)
5. Hood should pop open either with pull-up on car body or the remote key. IT DOESN'T.
Pictures:
What am I doing wrong here? Why won't it open?
Any suggestions/advice?
Thanks.
luci5r is offline   Reply With Quote
