Old 02-16-2015, 09:08 AM   #1
ルーカス
ルーカス's Avatar
Originally Posted by jeepdad View Post
Looks terrific. When restoring wheels like this, do you also primer and paint the inside surface? I'm considering restoring my 17" turbo twists. Also, I assume the wheels/tires would need to be rebalanced afterwards?
Thanks pal! I kind of just scuffed the barrel with some 400 grit so any over spray would stick. As for rebalancing I would definately do it. You're adding weight to rotating mass. I'm doing it regardless because I have some new rubber to go on!
ルーカス is offline   Reply With Quote
