Old 02-16-2015, 04:48 AM   #3
Smallblock454
The M030 contains:
Front Springs & Shocks
Rear Springs & Shocks
Front Sway Bar & Bushings
Rear Sway Bar & Bushings
I would recommend to replace everything with non M030 stock parts if you want to keep the 18" wheels. That is better / less harsh but doesn't mean a comfortable ride.
Easiest way to get the car a little less stiff is to use 17" wheels with the M030. If your Boxster is a non S, there'll be also the option to use 16" wheels and the M030 setup. Maybe this doesn't look sporty, but it drives better than 18" and M030 on bad roads.
