Old 02-15-2015, 05:53 AM   #2
Luv2Box
Luv2Box's Avatar
We've tried to have a constructive discussion about the SAI before but some 'green' views were expressed objecting to removing the SAI system.That was a thread killer.
In Europe they do not use SAI - not just Porsche but Jaguar and BMW also. And they are just as Green & polluted as we are. So there is at least some doubt about the efficacy and value of SAI.
Boxster owners in similar SAI threads mention the high costs of chasing down these SAI component failures.The diagnostic,labor and parts often rise to well over $1000, sometimes in multiple installments as initial repairs prove unsuccesful . That is a pity because other OEM SAI systems are simple,inexpensive and reliable(like the AC Delco system on my old Jag XJR).
This high cost repair is going to be a bigger issue for us as the cars age and simultaneously decline in value. So we really need a cost effective solution for those of us who run theses cars on a tight budget.
DME upgrade/flash for SAI delete -NO codes no more! - Rennlist Discussion Forums
Agreed, however, whatever the solution is it would have to pass the visual part of the inspection in California. My last smog test had to be done at a STAR station because the CMVD determined my Boxster "may be a gross polluter due to its age." STAR stations, as you know, must perform a visual inspection of the motor.
Luv2Box is offline   Reply With Quote
