Old 02-14-2015, 07:54 PM   #3
KevinH1990
KevinH1990's Avatar
I thought I would add one more piece of information from Renntech.
The gray wire in pin 10 is the signal that tells the litronic system that the lights are on. When I remove my trunk liner, I'll provide a picture of the location where I tap into it.
(The retrofit kit didn't need it since it only works when the high beams are on. The instructions for the retrofit kit tell you to tap into a white wire that carries the high beam on signal.)
