Old 02-14-2015, 04:31 PM   #1
Luv2Box
Luv2Box's Avatar
Originally Posted by Manny986 View Post
Thank you very much thstone, the codes I get are P0410 and P1411. Now I am sure that the pump is not starting as I validated today that the noise I am hearing is the engine cooling fan, not the secondary air pump. I have to determine if I have a fault pump or if something else is creating the problem.
Same two codes I've got with a CEL. I had it diagnosed and it is the main on/off valve that has failed. Problem is it fails in the on position so it continues to put ambient air into the manifolds so the cats heat up quickly on cold start, so it still complies with emissions but it burns out the other two diaphragms in the system because it allows hot air to blow back through the system. You're looking at about $800 for a shop to replace all three switches and the vacuum tank in the system (replace this as it is cheap and gets brittle and cracks over time). If you do it you can buy all three parts for around $200 and a few bucks more for hoses. Pelican Parts has a good diagram of the secondary air system and also has the parts at a good price. It is common in the early Boxsters for this system to fail but not common for the air pump to fail so check it thoroughly as the pump alone is around $1,200. I've been driving for almost a year with my system not working as it will not damage the car but it will not pass smog test if you have to have one. I swear, but can't prove, my Boxster runs better with the system not working as intended.
Luv2Box is offline   Reply With Quote
