Old 02-14-2015, 08:18 AM   #2
tommy583
98 Arctic silver 986
tommy583's Avatar
The old cable release trick will work fine. You can also use a small screw driver to move the cog on the release levers. It is in between where the levers meet. Kinda in the H part. Its hard to explain without pics. I know that works on the rear trunk, not sure about the front trunk. The release cable is probably the easiest and quickest way to go.
