Old 02-13-2015, 01:43 PM   #11
woodsman
woodsman's Avatar
Originally Posted by jaykay View Post
Nice...less hovercraft action! That is a quick and effective way of doing it!
...eventually you could go to mesh and seal the under side...but there has to be the correct amount of the cooling airflow through the liner.
I agree with the theory about venting the center rad upwards but how does introducing 10X the air volume into the front wheel- well reduce lift? With aero less is more- I think but than it depends on intended velocity. Auto makers spend days in the wind tunnel to make our cars 'work' with as little drag as possible. For instance, why increase flow through the rad by 500% ( my guess on JFRO'S liner) AND THEREFOR DRAG when blocking the bottom and venting the liner with 2 4" .25" slits would probably suffice? The key concern is ability to cool while creating the least amount of drag-right? At 60 mph we're hitting a cement-like wall of air and aero is gently persuading. And ya let's discuss- it's a FORUM so there's no need to get pissy or all-knowing.
