Old 02-12-2015, 05:22 PM   #11
BYprodriver
BYprodriver's Avatar
Originally Posted by steved0x;435925[B
]Ebs also makes a deep sump compatible baffle, maybe it has the equivalent to the trimming already done?[/B] I think it I designed for the bk derp sump nut maybe the mods are the same?
No the EBS baffle is designed to replace the stock one as it mounts on top of the oem pan "wall" I believe you need to trim your baffle flat so it will mount flat on the BK windage plate.
