Originally Posted by Trey T
Heiko: I removed my CV joint by removing the LBJ. However, I don't see what's so complicated about it. I've worked on a lot of FWD CV joints and I understand the toughness but that's only because I didn't have the proper tool or applied hte right method.
The special tools you need to get it completed are:
1. BJ spreader
2. Hub puller (5lbs hammer)
You can get all of that HF; I rented mine.
You guys must be lucky in the southern states
I've had a few here that the BJ spreader just wont budge apart. I've literally had to beat a few out, as the salt on the roads here seems to corrode things so well
My own however (which never see's salt) came apart easy...
H
