Old 02-10-2015, 06:43 PM   #7
dghii
Not advocating the bypass but to answer your question....
You can bypass the clutch switch if you choose. Potential downsides include starting the car in gear or not fully engauging the clutch when shifting gears.
I cannot recall for certain but I believe adding a wire between the switch terminals will bypass the switch. Try it. If your car starts you are good to go. If your car won't start. disconnect the switch from the wire harness and try it again.
High clutch engaugement may indicate a clutch replacement coming in the future!
dghii is online now   Reply With Quote
