Old 02-10-2015, 05:13 PM   #2
woodsman
woodsman's Avatar
Originally Posted by mgfranz View Post
I just noticed that my passenger window sits about 1/4" too far back when fully closed. The driver side is fine. Here are pics.
Passenger side
Driver side
You can see from the pics that the driver window sits almost exactly even with the "point" of the rubber seal. Is there a way to adjust the "fore/aft" of the windows without pulling the door card?
You can adjust the upper limit from the bottom of the door- outer 2 plugs I think. Maybe you can lower it .25" and other alignment will be adequate all around. Possibly 7mm torx or allen- I saw it in the Bentley manual.
