I had the same problem. I had a small crack in the coolant tank. Coolant leaked into the trunk and found a way out in front of the tire. Check your trunk carpet and see if it is wet. If so you have a coolant leak.
It is a DIY project if you have some time. Its a bit of a bugger but isn't too hard.
2000 Boxster S
