Old 02-10-2015, 07:58 AM   #10
Reebuck1
Reebuck1
Gauges
Thanks Kevin ! My problem was I could not get my EPROM reader to read the chip in on 986 mother board. Chip showed # as ( sc 56M ). This was not listed in the EPROM inventory. I tried entering the 93c56B chip
number but it showed no data when I tried to read the 986 chip. So I could not see the data on the chip. I had to take the car to the dealer because of a window issue that turned out to be a bad theft control unit.
(Waiting for part to come in now.)
I figured while I was at the dealer I would have them turn on my new cruse control install and also turn on the two new switches on my 996 gauge swap.
They tried BUT failed.
Reason appears to be the result of my installing the 996 motor and having my
986 DME flashed as a 996 ROW. The guy who did my re-flash locked the DME so it would not revert back to the original 986 coding if I disconnected the battery.
SOOOOOOOO we are trying to work our way through this.
Any thoughts on how to get at the flash chip?? It would be easier if I could just do the mother board chip instead of having to go the DME path.
Reebuck1 is offline   Reply With Quote
