Old 02-09-2015, 07:05 PM   #10
KevinH1990
KevinH1990's Avatar
On my 2000, I had to do the EPROM programming trick to get the voltmeter to work. That may be a difference between the "old" and "new" style clusters. The oil pressure gauge worked fine after I hooked up the 996 sending unit and inserted the wire in the back of the cluster.
The programming should also took care of the speedometer error and the top motion light. However, the top motion light on my 996 cluster worked before I programmed it. The VIN stored in the cluster indicated it was from a coupe, but it had the bulb already installed for the top motion light. So, the VIN decoder site may have had an error.
There was quite an extensive discussion on Renntech about this and most people indicated that the dealer couldn't help them.
