Old 02-09-2015, 09:00 AM   #10
BoxsterLS376
Originally Posted by JRL View Post
Hey John why can't you use the Boxster accelerator pedal assembly - it is drive by wire isn't it? Seem like the wires would be the same or at least similar enough. What am I missing?
Hey Randy,
Yes the porsche pedal is drive by wire, well the pedal itself is actually mechanical but it connects to an electric motor mounted in the dash. It is also a 6 wire setup like the GM unit, but i believe that the problem is in the voltages that GM uses vs. what Porsche uses, they no sprecken well~ Probably need a series of resistors or something - i'm sure you could make it work but when it comes to the throttle i'd like to keep it as simple as possible to avoid any potential issues.
J
BoxsterLS376 is offline   Reply With Quote
