Originally Posted by tommy24689
I have a 2001 Boxster S.
(1) I recently replaced the radio with a Pioneer single-din deck and it works, and sounds, great. I noticed that after the deck replacement, the horn would beep each time I locked the doors. Should I be concerned about this?
Three weeks later. . . .
(2) My ignition no longer "clicks" when I remove the key after driving the vehicle. Previously, I would hear a "click" shortly after removing the key. I am concerned that this is evidence of a faulty ignition switch. I garaged the vehicle, opened the front-trunk, and put a trickle charger on the battery to ensure future use. Do you think I have a faulty ignition switch?
Thanks everyone for your advice.
The stock radio has ground wires on the old chassis that needs to be grounded again with the new radio. It needs to be grounded for your alarm to work correctly again.
