Old 02-07-2015, 02:48 PM   #10
nicecar
Factory calls out for a new gear box case. $900.
My Indy guy says mill out old bearing / bushing, press in new bushing, add new seal, done. The gearbox case pops right off.
A roller bearing would be a permanent fix. The shift lever arm is held in by one clip and the arm's shaft is not worn at all.
so I guess the indy guy is fixing yours? I read a post a while back with an indy doing something similar for 600? I will bring this post to my indy and see if he is game . Thanks for the help!
nicecar is offline   Reply With Quote
