Originally Posted by nicecar
How did you fix shift lever leak?
Factory calls out for a new gear box case. $900.
My Indy guy says mill out old bearing / bushing, press in new bushing, add new seal, done. The gearbox case pops right off.
A roller bearing would be a permanent fix. The shift lever arm is held in by one clip and the arm's shaft is not worn at all.
'08 VW Touareg T-3 wife's car
