Old 04-17-2006, 09:56 AM   #11
KRZTACO
The Real Answer
Your coming into the corner/exiting the corner too fast.
Sounds like the throttle is floored and pushing all the weight to the back tires leaving no weight for the front.
Quick fix: EASE on the brakes slowly to drive more weight to the front tires for additional traction while in the turn (Left foot on brake, right on throttle)
Correct fix: Slow down before the turn by QUICKLY depressing the brakes (NOT SLAMMING), and EASE into the throttle while exiting, not only will you be FASTER but the car will feel much quicker.
FYI: even if you had racing slicks on, your car will still push through the turns as you described.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
