					Originally Posted by  barkinfool
				Thanks Giller, but can you also confirm you don't use the headphone jack to play - it just uses the lightning connector & that is all needed to play through the Becker?
No headphone jack.  Just that one lightning cable does the trick to charge and play.  Just be aware of how your ipod is set up and where it is sitting.  My iPod is somehow set to skip songs when it's shaken.  So, sometimes when I hit a bump, it will skip around a bit.
