Don't know if this helps but I put a 996 motor in my 986. Used 986 DME with a 996 ROW flash and lost none of my existing 986 functions. I should say with two exception:::::: I was able to eliminate the Post CAT oxygen sensors and the secondary air pump and vacuum lines. I also added a 996 gauge cluster and it worked well
with the ROW flash and 986 DME.
