I would not recommend removing the spring completely. It will not allow the pedal to engage a plunger switch correctly, and will throw an error code in durametric after driving a couple of days. Noticed rough shifting, and odd sluggishness, decided to put in a lighter spring from home depot and problem solved. Lighter spring rate, and plunger is depressed upon using clutch pedal.
