02-04-2015, 09:56 PM
#53
Originally Posted by 986_inquiry
I'm confused, did they refuse to change the plugs, even after you asked for it?
Because from the way your story is worded they just were not planning on changing the plugs because it was not necessary yet and the manual says it should be every 60k
Then when you found out they were not going to replace parts that did not need replacing you became upset?
Thank You for the story!
