Old 02-04-2015, 05:52 PM   #2
BYprodriver
BYprodriver's Avatar
The perimeter trans bolts only function is to secure the trans to the engine case. Porsche bolts are cadmium? plated to minimize corrosion believe it or not so I recommend re-plating what you have as new Porsche bolts are no doubt expensive!
As for the trans case, a light brushing with a brass brush should work well. The engine case corrodes easily & turns grey if left to soak in Simple Green. I don't know if the trans case is less volatile but it seems to be.
