Old 02-04-2015, 01:33 PM   #133
BoxsterLS376
Originally Posted by Lcrivers816 View Post
Hey bud,
Where can I get the motor and transmission mounts from? Direct from Renegade? I wish they told me that I needed the weld in crossmember in order to keep the e-brake =( Guess I'll be ordering that.
Greetings,
You will actually need 3 different bits here, the aluminum motor mounts from a corvette which I sourced used ones from Ebay for about $100~ as they are not available from GM anymore. The actual motor mounts are urethane mounts available from Hinson Supercars, don't have the part number on me but you should be able to find them on their website.
The transmission mounts are available through Windrush Evolutions - AKA WEVO~ Again i'll have to look for the part numbers when I get home unless I already posted them, but that took some back and forth as well as it seemed noone really knew what was going on and it took like 4 phone calls to get them ordered so you may be better off waiting til I find the part number
Originally Posted by shockandawe View Post
When you finish maybe you can make up a extra set of spacer,and or whatever's needed I would gladly pay you for them ,thanks.
Hello,
I may be able to do that for ya, I have made up some temporary ones for now but I think about 1/2" of spacing is about right. I'll just order some aluminum bar stock, drill some holes and cut them to size. If you don't have the tools available you a machine shop could probably make them for you too, or possibly your local metal supplier could cut them to size then all you need to do is drill the proper hole size. I'll get some finished up this week and post pics/dimensions.
Thanks!
J
BoxsterLS376 is offline   Reply With Quote
