Air box
I just used a piece of plastic I cut from the air box and RTV-ed (hot temp.) it to the air box. It works great and I do not have to worry about vibration or heat. I was concerned about the plastic welding and its potential strength.
You will have to use a long 40mm bolt and finder washer to hold the air box from the inside.....or at least I had to.
