Thread: Locked out!
Old 02-03-2015, 10:14 AM   #10
newBgeek
Both my key FOBs act the same way. The LED lights, but won't lock or unlock the car. What happens is that the soldering connections get tired after awhile. The LED is on a separate circuit than the radio.
Try this. Carefully open the key FOB and remove the electronics including the battery. You can bend back the rubber part of the key back so it should come out easily. Then carefully push the button that opens the car. What happens is that the slight pressure that you put on the battery as you press the button should be enough to close the contact.
Good luck!
newBgeek is online now   Reply With Quote
