Yes. Given the rim offset is between et40~50 and the rim width is not wider than 10".
If they are in that range, the chances of rubbing is very little. Even if does rub a little, it's an easy fix with a 5~10mm spacer
Any major (MAJOR) issues, just trash the 275s and buy new rears in the 265 series. And you'll be all set
Good luck with your deal
