Thread: clutch mods
Old 01-31-2015, 08:33 AM   #2
JayG
On the slippery slope
JayG's Avatar
Originally Posted by jaykay View Post
Well I am definately going to give this a try come the thaw...
I haven definaitely noticed some clutch out weirdness on up shifts where the bite point seems to have inexplicably changed .....and all of a sudden you are slipping or grabbing too much
If we can go by the observations in the thread, perhaps this spring and dash pot canister starts to get worn giving more friction or damping resistance after a time. This would certainly disrupt clutch out feel and actuation
more likely the spring has broken, I dont think it is a wear item. It either is broken or not
If it is harder to press in the clutch pedal, then spring is broken
'You can either replace the entire assembly for $75-100 or replace the spring by getting one from a junkyard orlook at this thread http://rennlist.com/forums/996-forum/343297-improved-clutch-action-dramatically.html
and it will tell you where you can locate a similar one.
Mine broke and I got one from Woody (itsnotanova) for IIRC, $15 shipped
Its an easy DIY
2004 996 Targa Tip
Instructor - San Diego region
