Old 01-29-2015, 04:30 PM   #359
kjc2050
kjc2050's Avatar
Originally Posted by mikefocke View Post
Get the Novus 1 2 3 kit if you have the plastic window. I swear after the first time I used all three the plastic window was more flexible (as if it had absorbed some chemicals) and wasn't as brittle as it had been. Use the polish about every other car washing and it stays nice and clear. Only difficulty is getting your hand and the rag all over the inside of the window really requires some contortions.
Mike, thanks for commenting. I do have the Novus kit but you're right - getting at the inside of the window is a job for an 85 lb Russian gymnast. I need to do a better job on the inside surfaces, as I tend to ignore them in favor of the "easy" side, and it shows. I'll try to get at it this spring.
