Old 01-29-2015, 02:51 PM   #12
JFP in PA
Originally Posted by KRAM36 View Post
How much does the Flat6Inovation DOF Retrofit kit cost?
Here is what he stated in email correspondence.
"Depends on which route you want to take. If you want to go with the standard
single row LN engineering bearing, (assuming replacing clutch and a few other
while in there items), it usually comes out in the $3000 range with the
tiptronic due to the extra labor of the tiptronic. If you want to go with the
IMS solution which utilizes an oil fed bushing system to replace the bearing,
that runs about $4000."
IMS replacement parts alone for an IMS Solution refit are approaching $2k, without labor. $4K to do one on a Tip is a fair price.
