Old 01-27-2015, 11:19 AM   #32
pjq
Metal Particles ......agh. What about the filter, did you cut it open and inspect?
After removing the three bolts to the flange, the flange should be able to rotate left and right. You'll need a small (SMALL) hammer and gently (GENTLY) tap the tabs of the flange so as to rotate it enough to get a grip with screw drivers or pry bars to lift it off.
You can google IMSB flange to get an idea what your trying to remove.
