Old 01-26-2015, 02:03 PM   #237
The Radium King
The Radium King's Avatar
that is odd. I understand that at low and medium rpms the 'tuning' aspect of the exhaust and intake come into play (ie, using restrictions in airflow to time pressure pulses with valve opening) but fuel trims should react and fix any of that. did the ecu have time to compensate between exhaust install and dyno? was the lean condition present throughout the rpm range, or just at max rpms?
