Old 01-26-2015, 07:53 AM   #30
PorscheFan5
Will do. Had taken the sump off and found some metal particles. See attached. Rest of the sump was clean...I plan also to take the cam covers off to take a look inside.
Any suggestions on how to get the IMS Bearing cover off? Although there is no oil (which is a good sign in and of itself) there is slight rust and the cover is jammed. I don't have the tool to take it off that the Porsche technicians have. Trying to pry it using two screw drivers is so far not helping. There is no place to wedge the screw drivers...Did apply some PBB and will try again in a day or two...
PorscheFan5 is offline   Reply With Quote
