Old 01-26-2015, 07:25 AM   #233
The Radium King
The Radium King's Avatar
how could you tell - via the narrow band o2 signal to the ecu, or aftermarket wideband? if aftermarket, was the sensor placed before or after the cats? if using the afr from the ecu, did the ecu not correct the lean condition? also, at what rpm were you seeing a lean condition - part throttle, wot, or both?
