I also have the same problem. I am going to clean my motor next weekend and then pull it the week after. Hopefully I can find the leak then. I actually have 2 leaks. 1 is as you described, coming off the blue wire. The second is definitely from a botched RMS job from a local repair shop (RMS was done less than 200 miles ago). I'll watch this thread and update if you havn't found it before me. Good luck.
