Old 01-24-2015, 05:29 PM   #327
JonD
JonD's Avatar
[QUOTE=Nine8Six;433070]I can dbl-confirm that Martin's ashtray install methods works just perfectly. The circuit is indeed 6.6volts however it delivers 9V when the SkyBreaker is connected. More than enough current flows to power ON the kit. Looks good!
1) Remove ashtray
2) Unscrew the two torx screws
3) Pull out the assembly and set aside (no need to unplug anything, switches etc)
4) Splice both brown & bleu ashtray light wires and terminate as you wish (soldered mines, covered with 2" of electrical tape. Sufficient)
Brown = ground (goes to SkyBreaker black)
Blue = positive (goes to SkyBreaker red)
No need to remove the console, the cabling is so small it's easy to push under with your fingers. My controller is now residing in the armrest compartment same as Martin's initial idea. I've hidden the 385 kilometers of wires under the carpet/driver's side however
/QUOTE]
Fred,
Sorry to be so pedantic (remember I'm a complete novice)
When you do this:
Does the ashtray light still work after you connect the skybreaker wires? Or does it eliminate the light? Not that it really matters if the light in there is lost, but just wondering.
Plus instead of soldering, I have these wire connectors I use so you don't even have to strip the insulation from the wires and no tape needed.
Sorry if this is a stupid question, I just don't want to short circuit anything
Thank You
1998 Porsche Boxster
986 Arena Red, Tiptronic Base
JonD is offline   Reply With Quote
