Old 01-22-2015, 08:53 PM   #309
particlewave
Say what?!
I'll have to check mine out. I didn't take a voltage reading when I swapped the bulb for an LED, but just calculated the resistor for 12V, assuming it was so...
Jon - there are 20 different ways to feed it its 12Vdc. That's what the whole car runs off from so it can't be hard. The kit even runs off a 9V battery and will last for daysss lollll
The ashtray's circuit was a bad idea from myself however... it a 6.6volt circuit. That will teach me to listen to the others (Charles? you there?!)
I'll tackle the rear clamshell brake light for my set-up tomorrow morning if weather allows. I'll report back on that. Some will want to hook it up on a dash switch, others on the center console window switch, where else.... rear brake lights circuit, etc etc
Let's see what the others do for theirs Jon - and then let's copy them lolllll
