Old 01-21-2015, 05:26 PM   #10
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by Viper10000 View Post
Hello all,
I have spent the last few weeks researching everything I can about doing the IMS bearing replacement. I have acquired the parts and tools and I will be starting the project tomorrow. I figured I would reach out and ask if anyone had any last minute tips/advice on this. Thanks in advance and I'll be sure to take lots of pictures along the way so that I can post them after I complete the job.
Set the engine to TDC. Make sure you really understand which hole in the front pulley is TDC so the engine is set there. If you're like me or many others, you want to jump in and start twisting bolts, but set the engine to TDC first. Make sure you have the appropriate bearing removal and replacement tools.
If it's a manual, you have access to the clutch. inspect it, clean it, replace what needs to be replaced. Check the flywheel / replace if necessary.
As has been stated already, read through the replacement procedure before starting so you know what to do next before you get there.
It's not hard to do and it's even easier to screw up, but with a little forward planning you'll have the satisfaction of doing it right yourself.
2003 S manual
