It adjusts the lateral position of the bead so it seats in the plastic side frame when you close the top. If the bead seats right, then lower the top partway and shove the tab in, because it's not needed. If the bead goes outside the frame, use the velcro to pull the canvas in a little. If it will stick (which most won't, after 10+ years).
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
