Old 01-20-2015, 09:17 AM   #256
The Radium King
The Radium King's Avatar
the turn-in benefits you are seeing are not from a square setup per se, but because you went wider in the front. now you've got the front locked-in and you can carry a lot more speed into corners but the back is now feeling loose with power on. what about 265 or even 275 in th rear to get it to stick a bit better.? if you like the square setup for tire longevity, what about softening your rear bar?
