I see people doing this all the time. The original procedure that I developed for IMS Retrofit doesn't use set screws and doesn't allow this to occur.
There's a small area at the bottom of the crankcase that will usually catch this bolt. Accessing this is questionable.
Do not start the engine!! If you do, the bolt will be drawn into the IMS drive chain and will create a massive failure.
US Patent 8,992,089 &
US Patent 9,416,697
